Viberation after clutch install?
Just installed a Ram ls7 replacement clutch into my 02' SS Camaro and had the flywheel resurfaced and put a new pilot bearing in. I had to shim the slave also. Got everything good and now it viberates around 2000-3000 rpm area. Any ideas? Never had a problem before.
Pressure plate was torqued in sequence and correct amount?
Break the clutch in for 500 miles then see how it feels. I had some chatter at first with an LS6 replacement just about all of it has disappeared after break in.
