02 ws6 Air delete
Old 05-07-2013, 07:58 PM
Exarth's Avatar
Default 02 ws6 Air delete
I am buying some race headers and wanted to know what exactly needs to be done to do the air delete. What do I need and how hard is it?
Old 05-07-2013, 09:43 PM
Microtech82's Avatar
You can just rip it out. The pump is located behind the driver's side headlight area; follow the rubber AIR hose that goes into your intake lid and it will lead you to the pump. Just disconnect the pump and start removing the rubber hoses. There are four hoses, I believe: the one from the lid to pump, another from the pump to the area next to the rear of the intake manifold, and the last two are the ones that extend down to the exhaust manifolds.
I didn't want to mess with getting the hoses disconnected from behind the intake manifold because my back is messed up. What I did was remove the metal connections to the stock manis and left the remainder of the rubber hoses. Only about three inches stick out from under the dash cowl. I left everything else and just pulled the fuse for the AIR system and my tuner cleared the resulting codes when he was tuning the car.
Unless you are aiming to clean up the engine bay, or want to save a couple pounds of weight, it's easier just to pull the fuse and tuck those hoses out of sight.
Old 05-07-2013, 10:28 PM
Exarth's Avatar
What do you do with the hole from the intake lid? Is there a cap or ?
Old 05-08-2013, 12:34 AM
SILVER2000WS6T/A's Avatar
Plug it up. I believe a freeze plug will fit in the side of the lid
Old 05-09-2013, 09:57 AM
skopers3's Avatar
This fits perfect. Part #42081
http://www.summitracing.com/parts/rn...del/new-yorker
Old 05-26-2013, 03:54 PM
Transam9973's Avatar
I just bought block off plates from one of the sponsers. I think they were $10-20 shipped then remove hoses and pump.
Old 05-29-2013, 02:34 PM
ridndirty1000's Avatar
you could just unplug it and leave the pump in that would take you only 5 mins
Old 06-02-2013, 12:57 PM
2000 TA owner's Avatar
Im old school goimg to delete egr and air want to know what the air pump actualy does
Old 06-02-2013, 01:30 PM
cdgreg's Avatar
https://ls1tech.com/forums/generatio...gr-delete.html
thread I was reading earlier today similar to this topic.
Old 06-03-2013, 02:47 AM
black_phoenix's Avatar
block it off with a plate (on the headers) most likely the plate will be provided
Quick Reply: 02 ws6 Air delete
