My On3 Non AC Build
My On3 Non AC Build
Little Background, I have had my 2000 Trans Am since 2008. Bought it after my 1999 Trans Am was totaled after being Rear ended By a H2 Hummer. I always Wanted to do a turbo Build but funds would never allow it. I finally Bite the bullet this winter and started ordering parts. The motor needed all new Gaskets and I figured if I was going that far just go all the way.
Stock Long Block
LS6 Intake
FIC 60#(72# on My Fuel System) Injectors
Brain Tooley Springs
Summit Under Drive pulley(already had)
Manely Pushrods
WS6 Store Catch Can
SJM ABS Delete/Line lock
Lokar Throttle Cable to delete the TCS
Battery Relocation
LC-1 Wide Band(Already had)
On3 Performance Non AC kit(76mm Turbo, Turbo Blanket, Scavenging pump, 4" Intercooler)
HPTuners(already had)
AC Delete Panel, Kept Heat.
Summit Racing universal hoses
Griffen Radiator
Flex A lite Fans
Permacool Trans Cooler and Fan(Already had)
Performabuilt stage 3 4l60e with 4000 stall(Already had)
Racetronix 255 with harness
Before The Build
The Build
Tired of being harassed about my plate being mounted low.
New Tires hope to Install Tomorrow
I also picked up a 3.42 Rear to swap in this weekend, my 3.73s are just too much now. And I am waiting on Greg banish Tuning DVD so I can finish Dialing in the Car. Sorry some pictures are out of order. I hope to get some better Pictures this weekend. So far she is a beast. I haven't been able to get Traction, That's why I bought the Mickeys.
Stock Long Block
LS6 Intake
Manely Pushrods
WS6 Store Catch Can
Battery Relocation
Griffen Radiator
Flex A lite Fans
Before The Build
The Build
I had to cut the HVAC Box Flush with the fire wall, Cut a passage for the air to flow and then fiber glassed that. Then cut a hole in the delete panel for the heater hoses. Its clean, Heat works Great. And access to the Spark plugs is great now. Theres a few write ups on the forum.
cool man well hopefully when you get all the little things worked out you can post some videos. i have yet to find an actual on3 turbo kit on an fbody video anywhere...
Yes front tags are required. used to run it under the bumper but started getting harassed.
Not much for updates. It survived Cruising OC, Cranked the boost up to 10 Pounds. Big change going from 6 to 10 pounds. My Wideband stopped working by the end of that weekend, I think it has something to do with how close it is to the turbo. Need to get a new sensor and play with the tune some more, She is a bit fat at WOT. Might try to hit 75-80 drag way in a week or two.
