My build 1sc z28
My build 1sc z28
This started life as 1sc 1sz stripper and I picked it up as a roller and coming back to life. few mods along the way. I did not doc the whole process just got to work. heres a few pics of my ride goal 9.50 all motor.
If you want better pics I will post
my stripper drag build
2002 1sc z28 2000 miles on clock
350 trans brake
5000 stall
456 12 bolt moser/ strange
stock block 347 cubes
etp head milled cannted .250
485 rwhp on very loose convertor
c-14 very thirsty engine @$15 a gallon
phil hoefler pcm tune
afcos da
fabbed fuel tank
10.50 @ 131 first pass on qa1 singles made 3 passes 10.50 test tune suspention needs dialed in, swapped to afcos over winter
350 trans brake
5000 stall
afcos da
fabbed fuel tank
thanks! pain to make ls1 engine bay clean, shaved the heater box spot welds etc etc. The heads are ETP milled and canted high comp
