AC line repair
Old 05-09-2013, 07:22 AM
maxgee's Avatar
Default AC line repair
Hose got damaged and needed replacement. My turbo set up makes it extremely difficult to remove the compressor to replace. I found a kit that splices into the aluminum line thus repairing the line. Haven't tested it yet; debating weather to just put a can in to see if it holds, or get it vaccumed first.
Old 05-09-2013, 09:09 AM
Homeless2bNY's Avatar
if all seals are in and correct.
it it vacuumed down and see in it leaks that way.
if it holds for 10 min with out gauges dropping fill it and recheck.
Old 05-09-2013, 03:59 PM
maxgee's Avatar
I dropped it off at 4pm, they are going to see if it holds vac, if so, they will flush than vac for an hour than charge it.
Quick Reply: AC line repair
