Help get my car to start
Old 05-09-2013, 08:44 PM
Z28Roxy's Avatar
Default Help get my car to start
At my wits end here.....
I went through the no start diagnostics:
http://www.mainstreamtopics.com/foru...rt-diagnostic/
I am getting fuel.
And based on it I should have replaced my opti. I did. No start. I also replaced my coil, ICM (I have spares), coil wire, ICM connector, checked all fuses, made sure everything is plugged in, checked for continuity on wires everywhere and everything is good. My VATS is disabled and bypassed.
But the car cranks and there is no spark (did the spark plug in a spark plug wire test) AND the odd thing that happens is my gauge cluster is reading all kinds of fucked up (only thing I can think that has anything to do with it at this point). It reads stuff like battery volts pegged, 3200 rpm at all times, ASR on (car doesn't have ASR).....
Blah so someone help plox!
Old 05-09-2013, 08:51 PM
BoostedDSM's Avatar
check voltage to the opti, would be my first guess to why you don't have spark if it's new or to the coil. Silly question, but everythings plugged back in and all that fun stuff?
Old 05-09-2013, 08:53 PM
fastassls1maro's Avatar
my buddy had an lt1 that snapped the timing chain which lead to no spark....it had a replacement timing chain from advance that broke. I assume the car was running at one point? what happened that the car will no longer start?
Old 05-09-2013, 08:55 PM
Camaroz's Avatar
I'm just here for the free sex. Did you check grounds?
Old 05-09-2013, 08:59 PM
Z28Roxy's Avatar
Minimum stuff connected to get it to start. OPTI / damper / coil / icm / MAP. Yes my opti and coil wires are hot too.
I just parked it one day and it would no longer start. I had been losing guts up top (ignition or fuel break up) though.
Yep grounds are good.
Old 05-09-2013, 09:00 PM
Bowtie316's Avatar
Did somebody say free sex?
I would think that you may have an ignition switch problem or a body ground somewhere that is not grounding. Like someone else said, do you have power at the opti? what about all the pins at the pcm? Might have to check it while cranking to confirm.
Money1's Avatar
Check the crankshaft position sensor.
Old 05-09-2013, 09:02 PM
Z28Roxy's Avatar
It doesn't have one, it's a 95.
Old 05-09-2013, 09:20 PM
Camaro350Z28's Avatar
whats the opti harness look like? check where its plugged into the opti. see what it looks like. i had one so corroded it would not start
Old 05-09-2013, 10:31 PM
Puck's Avatar
Sure know how to title a thread for responses.
Wacky gauges are almost always due to either a poor ground or bad computer. Do you know anyone with an LT1 that would let you test the computer? Even if its not the correct tune for your car you can at least put it on acc to see if the gauges behave.
Old 05-09-2013, 10:32 PM
96capricemgr's Avatar
I had a female pin on the opti end of the extension harness get pushed in too far, harness probed fine because the multimeter probes are longer than the male pins on the opti.
Old 05-09-2013, 10:34 PM
baalic's Avatar
My guess is going to be a bad ECM or computer. LT1's have ECM's or PCM's? ? Never owned an LT-1 but ya that was my thoughts.
Old 05-09-2013, 10:40 PM
robsquikz28's Avatar
LMAO ROxy
alright if you have another pcm put it on and check it over.
I would check all the wires above the battery. For the power and ground cables that go on the passenger fenderwell. Make sure they are tight! I have seen these lose and cause no starts, erratic gauges, die outs while cruising.
Do you have a Live read scanner at all?
Old 05-10-2013, 07:14 AM
Quazz's Avatar
You are in Waukesha, huh? I have to come down to LMT to pick up my 94 either tonite or tommorow during the day, i could always stop by and lend a hand. I would try looking at the Opti harness. Mine physically looked okay, but if you pulled it the wrong way, the car would die. I replaced it and had no issues.
Have you checked for spark at all?
Old 05-10-2013, 07:35 AM
96z28_lt1's Avatar
i've replaced optis before with cheap units that would cause no spark. But i agree that the gauges sound like a funky battery or pcm problem.
Old 05-10-2013, 07:44 AM
quik95lt1's Avatar
well I got a gf so im gonna have to pass but ill still help
did you verify you have voltage at the IGN/PCM fuses in the fusebox? also pop off the connectors on the pcm and see what they look like, im willing to bet they aren't gonna be pretty ive seen this before with corroded pins and terminals........
if all is good and you think its a pcm ive got my old one that had a tune in it for my heads cam 355 if you wanna pay me shipping ill send it to you to try, just send it back when your done please
Old 05-10-2013, 09:12 AM
Z28Roxy's Avatar
I am actually in Elkhorn, not Waukehsa (need to update location).
LMT? The opti harness is fine.
Old 05-10-2013, 10:27 AM
Quazz's Avatar
LMT = Late Model Throttle in Waukesha
Elkhorn isnt too far, I'd still be willing to stop by. (no sex needed LOL)
Old 05-10-2013, 10:43 AM
sweetbmxrider's Avatar
You grounded the plug when you were checking for spark, right? Did you check for spark from the coil?
Old 05-10-2013, 11:05 AM
Z28Roxy's Avatar
Yeah I grounded it to one of the metal brake lines. I also checked at the coil. Nothing
Quick Reply: Help get my car to start
