Hose on torque arm
Hose on torque arm
So I noticed there's a broken hose dangling on my exhaust. Further inspection shows it's mounted to the torque arm and then is cut off mid length towards the rear differential on that end. However it runs along the transmission and then runs towards the top of the bell housing. Who knows what it is?
No more than my ragged out B4C already had... LOL! But if you had vapor pressure in the trans case after your car heated up and you were sitting in traffic, the vent point without the hose is higher in the tunnel than with the tube outlet. That's just food for thought...
"All Motor 9 Second club member"
Yes that is the vent hose from the transmission. It is routed to the torque arm and secured to the TA with a clip. You may have gotten a drip of residual fluid that dripped onto the exhaust. If the rubber hose itself touched the exhaust you will definitely get a nasty smell.
