241 Heads and stock cam plus more!
Category: Engine - Power Adders
Price: $300
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): CA
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Used 241 Heads with the stock cam ($300.00)
About the heads... for some reason I can't locate 2 of the lifters that I pulled out when I pulled them out. I also can't find 2 push rods. I used the Lifter tray bolts and Rocker arm bolts on my new heads with all the new guts in my new heads. So if you get this you need 2 push rods, 2 lifters and the bolts that hold the rockers and lifter trays in the heads. (You can reuse yours out of your old heads)
Used Smog pump ($40.00)
Used Stock Headers ($75.00) (SOLD)
Used 25lbs Fuel injectors x8 ($80.00) (SOLD)
Used Stock Headers and Cats and Y-pipe $200.00 (SOLD)
NEW TSP LS6 Oil Pump: ($75.00)
NEW LS6 Timing Chain with both NEW gears ($185.00)
NEW Oil pan gasket ($40.00)
Joshua,
Message for pictures if needed.
