pressurized crank case/catch can??
Old 05-11-2013, 11:01 AM
1bad03snake's Avatar
Default pressurized crank case/catch can??
Ive been searching for a few hours about a crank case vent system for my car. Does anyone sell a complete kit for this? I have a 6.0L and a tc78 turbo.
I have a breather on the driver side valve cover and was going to add one to the oil fill cap. To keep crank case pressure down.
Old 05-11-2013, 11:16 AM
ramairetransam's Avatar
rx dual valve catch can is what i have
Old 05-11-2013, 12:02 PM
I8UR4RD's Avatar
This is usually the better cheaper option IMO.
https://ls1tech.com/forums/forced-in...ntilation.html
Old 05-11-2013, 12:56 PM
I found this setup
http://www.hawksthirdgenparts.com/pr...-%26-Hose.html
Old 05-11-2013, 12:59 PM
LS6427's Avatar
Go breathers.......screw PCV systems. How dumb of a design is that to allow oil into the intake.....lol
Old 05-11-2013, 02:40 PM
I8UR4RD's Avatar
thats the same way I looked at it 427.....I thought, well spent a grand on this intake....now I am going to blow nasty *** engine oil all inside of it and my engine.....no way hose'.
Old 05-11-2013, 03:07 PM
LS6427's Avatar
Yup.....and I personally change my oil every 3,000 miles, so contaminated oil is a none issue for me.
Old 05-11-2013, 04:28 PM
Put a breather on the pass side valve cover vent and one one on the oil cap and let her eat? no catch can?
Old 05-11-2013, 05:14 PM
I8UR4RD's Avatar
I change mine (or will soon) every 500.
Old 05-12-2013, 10:39 AM
dmaxvaz's Avatar
how about this: 1 -10an fitting in each valvecover to a vented catchcan, then have the ls6 vallley cover hooked up to the turbo inlet?
Old 05-12-2013, 11:05 AM
MIGHTYMOUSE's Avatar
i have made cans that are specifically designed to relieve crankcase pressure. (sig) and maintain full pcv
Old 05-14-2013, 11:21 PM
itsslow98's Avatar
I have a mightymouse catch can for my car. We just put one on a buddies car and it works perfectly. There are benefits to not running breathers like better ring seal so running a properly setup closed catch can is the way to go.
Old 05-15-2013, 07:46 AM
hey do you have any pics i could add to my site (see sig)
Old 05-15-2013, 11:24 AM
JetMech99's Avatar
I too run the MM catch can with the build in PCV for boosted applications. Great quality, great price and gets the job done!
Are you looking for installed pics of your cans MM? I can snap a few for ya if you need.
Old 05-15-2013, 11:59 AM
pwrtrip75's Avatar
Use the factory air valve and run it into your exhaust to scavange. I have it hooked up to my catch can and it maintains a vacuum there from the exhaust. Works great.
Old 05-15-2013, 01:00 PM
thanks very much and yes
Old 05-15-2013, 01:06 PM
Slow94Formula's Avatar
MM catch can FTW! I have some pictures in my build thread.
Old 05-15-2013, 02:05 PM
b16gsr's Avatar
I will get you some pics when I get mine installed.
Old 05-15-2013, 09:37 PM
itsslow98's Avatar
Ill take some DSLR pics of mine when its installed. You cant see where my buddy installed his because the turbo is behind the front bumper and he hid the catch can since he did a wire tuck. Mine will be in the open since it will match all my powdercoated stuff I had done for this motor.
Old 05-16-2013, 06:40 PM
allout06's Avatar
so. 2x-10an fittings to a vented can isnt enough? i have after market covers with no PCV provisions, and an LS1 valley cover. twin turbo.. i was gonna do the 2 fittings on the covers to a can... thoughts?
Quick Reply: pressurized crank case/catch can??
