Door speaker replacement? 99 camaro
Old 05-12-2013, 05:44 PM
ls2 bait's Avatar
Default Door speaker replacement? 99 camaro
Yes it has the monsoon. I dont need show quality sound I just want music when I drive it. Has an aftermaket pioneer headunit butnall stock beyond that. The sail panel speakers dont work w the aftermarket unit though. But I am on my 3rd oem door speaker they keep blowing. (Over the last 7 yrs) I just want a decent replacement. Point me in a direction?
Old 05-12-2013, 06:28 PM
homerunhtr21's Avatar
Look up kee audio. He has a direct replacemnt kit. Makes it Bout as simple as it can get. And ian is great to work woth.
Old 05-12-2013, 09:41 PM
ls2 bait's Avatar
The one package shows all 6 speakers but not all 6 function with the aftermarket head unit. Any way to fix that? If so i would consider doing them all instead of just the doors.
Old 05-13-2013, 07:22 AM
Ungrounded Moderator
WhiteBird00's Avatar
Huh??? Of course all six will work with any aftermarket head unit. What makes you think they wouldn't?
Old 05-13-2013, 08:08 AM
ls2 bait's Avatar
Not in my car. The sail panel speakers are silent. Put the stock head unit back in and they worked fine. The ones in the hatch still work as do the ones in the doors.
Old 05-13-2013, 08:15 AM
Then there's something wrong with your car. A properly wired and configured aftermarket head unit will work exactly like the factory one.
Old 05-13-2013, 01:55 PM
Avaric3's Avatar
Only thing I can figure aside from a botched wiring job, is that you've set the hpf to a range that renders the sail speakers useless
Old 05-13-2013, 09:01 PM
ls2 bait's Avatar
Its got a metra wire kit. Plugged right in. Stock radio in and it works fine. I do have the high pass filter on trying to spare the door speakers though.
Old 05-14-2013, 07:01 AM
Turn off both HPF and LPF settings - the Monsoon amp handles all signal filtering internally.
Quick Reply: Door speaker replacement? 99 camaro
