Nitrous Plate Location
Old 05-12-2013, 11:01 PM
Ls_Notch's Avatar
Default Nitrous Plate Location
Im about to put my plate system on the car and I am running a vic jr with a 2 in spacer so should I put the plate right under the carb or under the spacer where it will be more even going into the runners? Its a nitrous express gemini perimeter plate. Im going to try it without the spacer too since im not spinning the motor above 6600-6800. What do you think will give me best results?
Old 05-13-2013, 01:34 PM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
You will want the plate to be directly on the manifold. Then the spacer on top of the plate.
Trey
Quick Reply: Nitrous Plate Location
