ls1 blocks prior to 2001?
Old 05-15-2013, 03:49 AM
richard_956's Avatar
Default ls1 blocks prior to 2001?
I'm doing a replacement engine swap on my 2001 camaro ss. I found a block but its from a 99 I believe. Where there any major differences between the blocks that may put me in a disadvantage?
Old 05-16-2013, 01:40 AM
2000PewterT/A's Avatar
No your fine, some small differences in the 98 block IIRC but don't quote me on that. Either way there is no difference that would hurt performance anyway.
Old 05-16-2013, 06:50 AM
Blackpanther99's Avatar
That^ You might see lower HP but nothing major as far as having issues go.
Old 05-16-2013, 05:06 PM
JDEP162's Avatar
There were a few differences in the block, but nothing that changes a build, they made small improvements over the years, bay to bay breathing and such, but all parts are interchange and with performance replacements the block has no differences. A percent of the last f bodies did recieve the ls6 block, as well as intake, but parts are still interop.
Old 05-21-2013, 12:48 AM
Alright guys, I just got my block today. I will try to post pictures of it and some of the block I pulled out of my ss. I also got my hands on a cam that comes from a 6.0. Would that require bigger springs,(I bet) and lifters?
Old 05-21-2013, 04:05 AM
A stock cam from a 6.0 would not need different springs, though I always like to put in fresh springs if I am doing a cam swap, that being said you won't need anything like a double spring etc. If it was my car I would look into a nice cam package with some lifters from a sponsor on here. A 6.0 cam wouldn't do much of anything for a power increase.
Old 05-21-2013, 07:51 PM
murphinator's Avatar
its my understanding that the early 6.0's ( built around the same years as the 4th gen ls1 cars) shared cam part number with the 99+ ls1
Old 05-22-2013, 08:17 PM
LSPOWEREDS10's Avatar
If you want to put a small cam in the motor without blowing the budget a ls6 cam would be good and matching yellow springs
Old 05-25-2013, 12:49 PM
bww3588's Avatar
01 is when they changed to the smaller truck cam to get rid of egr.
Quick Reply: ls1 blocks prior to 2001?
