93 lt1 firebird need help
Old 05-15-2013, 08:35 AM
kblaze9710's Avatar
Question 93 lt1 firebird need help
ok so I started a post before but im still having issues I keep burning up ignition modules now I need help trying to figure out why its doing this anything would be great
first thing my security light stays on I can start my car without the pill in the key/wires hooked up also my air pump went out so I just hooked the hose to the ram air box so its constantly sucking air I just replace plugs wires and msd cap and rotor ive gone thru 3-4 ignition modules im getting 12v to the icm like it should ive I checked resistance in the coil everything checks out fine I have a code for the air pump think its code 26 dk if its setting the computer telling it its running lean/rich so if anyone has so info I greatly appreciate it
Old 05-15-2013, 09:17 AM
KFtransam's Avatar
Check the ground strap going to the head/icm
Old 05-15-2013, 10:21 AM
kblaze9710's Avatar
the ground strap is good and I got ground going to the icm
any other ideas
Old 05-15-2013, 09:41 PM
kblaze9710's Avatar
Ok i got my security taken care of i put resistors in and solder it under colum now i am only getting 5v to the ignition module is that bad or and ideas where i should start next
Quick Reply: 93 lt1 firebird need help
