95 v6 camaro 5.3 swap
Old 05-15-2013, 04:01 PM
95ls's Avatar
Default 95 v6 camaro 5.3 swap
so i was given a 5.3 vortec complete motor with harness and ecu from a yukon i believe. and i picked up a 95 v6 for $450 bucks. so i want to put it in my car and end up turboing it but that will come after its in and running. i plan using t56 but the 4l60 seems easier to find and much cheaper. my question is wiring and what i need to wire it properly. i know i need ls1 steering oil and intake. also what cam will runn decent n/a and work with a 10-12 psi turbo setup later. i want to run ls6 intake and the head from the 5.3 with new spring and valves. any help is good help thanks.
Old 05-15-2013, 11:30 PM
Jose93z28's Avatar
Old 05-23-2013, 11:14 PM
camaromotorsports's Avatar
you will ahev to change the front fuse block harness to have 2 inj fuses and you will need a ls harness for eng and dash , and a k member for ls car , radiator for v8 car , radiator will have an extra nipple under the cap on the pass side , you will need a v8 tans crossmember and a driveshaft due to yours is a 2 peice shaft
Old 05-26-2013, 12:22 AM
the_merv's Avatar
Use this for a reference...
https://ls1tech.com/forums/conversio...on-sticky.html
Quick Reply: 95 v6 camaro 5.3 swap
