2 stage shots
2 stage shots
Want to see if this would be safe and your thoughts. Just aquired a 2 stage system. Would it be safe to shoot a 100 out the hole and bring in a 150 shot couple seconds later. Would you stack the shots or bring them on indepently. My setup stock bottom end ls1, 5.3 heads, v3 cam, ls6 intake, hooker headers, vig 3800, p&p tb, ta diff girdle w/ 3.73's.
Okay, now this makes a bit more sense lol! If you want to go through all that trouble to set up 2 stages exactly how you want then that's cool, but if it were me it wouldn't be worth the hassle
With a good tune it will live way longer than you think. As Cam or Andy how many passes they have on their stock bottom ends spraying 300+ size shots.
I see you have your screen name as stroked383hsr. In our crew we have a 127,000 mile stock bottom end, head and cam holley stealth ram on a 200 shot as we speak. In a 1992 25th anniversary camaro.
Just to give you guys a little idea, here is a guy on here with a stang with a 5.3 with a 200 shot.
https://ls1tech.com/forums/single-di...p-mustang.html
Here is a stang with a stock bottom end LS3 on a 250 hit running 8's
https://ls1tech.com/forums/single-di...cond-club.html
Lol....I hear ya bud. Yeah I no longer own the iroc ...it was a beast for what it was but my ta is way stronger.
So when you say stock bottom end do you mean un touched with just a top end package added? I just couldn't see hittin my 213xxx mile ride with that heavy of a shot ....I'm scared to hit it with a 100 ...LOL
When spraying a motor it just like the old saying "guns don't kill people, people do" well the same goes for spraying a motor "nitrous doesn't kill the motor, people do". 9 times out of 10 when a motor blows from nitrous usage, its always user error in not setting it up right or not checking the tune. Nitrous itself doesn't hurt the engine.
Off topic: the camaro we have runs 11.80's on the motor and you can pretty much guess where the nitrous time is.
Here is another thread of a stock motor with just an MS3 cam and a 200 shot. Check out the vid in the thread.
https://ls1tech.com/forums/single-di...new-setup.html
ive sprayed a 200 shot on my stock 1999 5.3 and i've yet to run into any problems (knocks on wood)... besides it eating the pinion gear out of my 10 bolt lol. if you had a nos mini you could set up both stages to just ramp in at set points (traction allowed) thats the route i would go.
