lots of c5 parts in NY. wheel, tires, K&N, etc
Category: Accessories
Price: $100
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO
Location (State): NY
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
- Barely used (might even be new) Wilwood 15Q-6828 (pad 7416): PolyMatrix Q Semimetallic Superlite Set -*$80 shipped ($125 new)
- New Wilwood 150-8854K (pad 7420): BP-10 compound, 20mm pad thickness (.80 inch) -*$55 shipped ($65 new)
c5 Rigid tow hooks (not hinged). $75 shipped for both (front and rear). No bolts included.
c5 Electron blue gas tank: very good + condition, $60 shipped
Corvette Mods.com z06 screens: new $90 plus shipping. Below - $80 shipped!!
Z06 replica wheel, 18x10.5, +53mm back spacing (I think stock z06 backspacing is +58m). Rattle can painted but flaking off in spots. $150 shipped
Stock c5 corvette rear discs (5). Seasoned and great replacements. Drop off only at race track. $75 for all five.
c5 Brake calipers, all four (front and rear), stainless lines, brackets $100 for all (plus shipping - heavy). Not pretty but functional
Fat Momma Frame savers - $55 new plus shipping. $35 shipped
Goodyear F1 Supercar tires, stock c5 z06 front size. $150 for the pair. two (2) 265/40/17. 5/32's tread. stock is 8/32's.
c5 z06 titanium cat-back mufflers/tailpipes.
- The first set at the top of the picture below is complete. $300 picked up.
- The 2nd set has a busted tailpipe on the left side muffler. it's a clean break and can be welded. $200 picked up.
- The last one pictured is just passenger side. $150 picked up.
K&N air filter for 1997-2004 corvette $55 new shipped typically. This needs to be cleaned: $25 shipped
All pictures are here:
http://www.ponycars.net/carstuffforsale.html
thanks guys - just want to make sure you see the caliper rubbed on the wheel. see the silver coloring, top left of picture:
http://www.ponycars.net/images/tempi...2_1024x577.jpg
not sure how it happened because it happened to previous cars owner.
That's the passenger side right? IIRC, the ones I bought did something similar and the pistons warped. It looked like as if the brakes had exploded under an extreme braking. Nicks and gouges all inside the caliper and the piston heads were smooshed and not flat anymore. The gap for the boot on the piston had effectively been crushed out of existence. I had to special order a set of stainless steel ones for my setup since no one makes or carries the stock ones anymore.
