need trans am shorty antenna
Old 05-17-2013, 08:34 AM
SPRAYED 01's Avatar
Default need trans am shorty antenna
I've read all about the bitviper antenna but from what i understand it only work if you have a fixed non motorized antenna from the factory. I want to get rid of my motorized antenna and get a 3 inch fixed antenna. Any one do this?
Old 05-18-2013, 07:49 AM
Save the manuals!
wssix99's Avatar
There are a number of posts that list the parts needed to go fixed.
I went with the hidden antenna and welded up the hole for the OEM one. It works great downtown.
Old 05-18-2013, 09:06 PM
SPRAYED 01's Avatar
I don't want to fix my stock one, i just want a fixed shorty that looks good
Old 05-19-2013, 11:46 AM
That_One_Person's Avatar
I'm also interested in this. Brother's TA's powered one is busted.
Old 05-19-2013, 05:24 PM
Save the manuals!
wssix99's Avatar
This is a great alternative for folks near populated areas: https://ls1tech.com/forums/stereo-el...m-antenna.html
This is how you get it to look "good": https://ls1tech.com/forums/general-m...haved-you.html
Old 05-19-2013, 06:54 PM
Ungrounded Moderator
WhiteBird00's Avatar
The factory power antenna and fixed antenna are interchangeable so there is no reason a replacement shorty antenna wouldn't work regardless of what you had from the factory.
Old 06-05-2013, 01:17 PM
eteller's Avatar
My power one broke, no way I was dropping a $100 for another PITA power antenna. Got a boat antenna off of ebay for $4, ran it up the side panel towards the roof, works okay not great.
Quick Reply: need trans am shorty antenna
