engine not receiving fuel pls help!
So i put an ls2 in my 96 camaro. Everything works and the engine will start if I pour gas into the intake, but no fuel is going to the engine.
Ive tried bleeding it from the valve
The filter is getting fuel to it, and when I disconnect the fuel lines from the engine gas will come out of the lines when i start it.
Idk, I'm almost done and then this happens!
LS1TECH Sponsor
The easiest thing to do is to jump full time power to the pump. This will allow you to run the pump, check pressure etc. without trying to deal with the 5 sec prime pulse.
If you can get the pump to work his way, then you can go back & diagnose your wiring... or you will quickly prove the pump is not working correctly.
Im not getting any pressure....
What I did was switch over the gto pump into the camaros and modified it..... but the camaros has 4 lines and the gto has only 2 but I didnt cap them off, so maybe that is why it isnt building any pressure?
Going to cap off, hope it helps
Ty
Ty
So I capped off the two lines and it made it worse.
I realized I had main feed going to evap, so switched it and now it will start up but will not stay running....
so idk
so idk
