Which intake should I go with?
Im aiming for 1000rwhp with the build.
Callies Compstar crank and Rods....Arp rod bolts....Arp Main studs.
Forged dished diamond or wiseco pistons
Compression will be fairly low. 8-9:1
AFR 230 or TES 235 heads
Single S480 turbo 96mm 1.32 ar T6 housing
MSx3 setup
Havent decided on injectors yet
What intake do you suggest I use?
Holley Hi ram? Edelbrock super victor? FAST? Other....
Thanks
MSx3 setup
Thanks
