g8 looking for its first 11's
i ran a 12.1 @ 116 1.87 60' at 2200 da, full bolt on cam and stall g8
shitty 60' need to learn to not launch like a bitch, maybe i need a higher stall i have a yank 3200 right now and looking to get a yank 3600 im sure thatll put me in the 11's, cant wait!
and with traction you'll get the most out of whatever da you're running in. Your car should be laying down 1.6 60 ft. times. You should be running at least 11.5 at 118 with good da and a dead hook. Maybe try some Mickey Thompson et streets If you change the converter go for one that hits around 200 rpm over wherever your torque peaks to get the most out of it, otherwise changing may not be worth the effort or cost. What cam are you running?
