Whats the point of an LS7 MAF?
Old 05-20-2013, 10:23 AM
Ferocity02's Avatar
Default Whats the point of an LS7 MAF?
Can someone explain what the point is of a 4" LS7 MAF sensor if the stock PCM is limited to 512 g/s? With boost it's not too hard to hit this limit. Perhaps the LS7 MAF is more for NA applications to reduce intake restrictions? I think the LS7 MAF is capable of reading more than 512 g/s, but will be limited by the PCM? Is this correct?
Old 05-20-2013, 10:42 AM
sreve's Avatar
The tune can be scaled to get around the limit.
Old 05-20-2013, 11:55 AM
Moderator
jimmyblue's Avatar
It would still be better than the 85mm Delphi, which
hits the 12kHz limit first (about 460g/sec). But I bet
it's mostly "bigger is better", letting people match the
rest of the plumbing on big TB setups (whether it has
much impact, or not).
Old 05-20-2013, 12:26 PM
Ferocity02's Avatar
True but you would lose resolution which isn't good at low airflow and idle, correct?
Old 05-20-2013, 02:03 PM
LS1Tech Sponsor
Alvin@PCMofNC's Avatar
We use them regularly in Gen 4 applications like Trailblazer SS's, LS2 Vettes, etc. We also use them quite often in hotrod/street rod builds. They flow quite a bit more than even the 85mm units. The PCM can be scaled to get around the 512 limit.
__________________
See what's in our shop on Facebook! Customer Build Blogs!
www.pcmofnc.com
Performance Installs - Dyno Tuning - Custom Camshafts & Valvetrain - Remote HPtuners Tuning - Mail Order Tuning & Sales
704-307-4227
Old 05-20-2013, 05:52 PM
LS1Tech Sponsor
Slowhawk's Avatar
Have seen that problem a lot. Drivability can suffer.
E-40 and E-38 computers love them but I've had problems with the older computers.
Old 05-20-2013, 07:53 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
Sometimes there's not always another option.....eg 98 cars with efi live.
Old 05-20-2013, 09:55 PM
Exidous's Avatar
If you screen the 4" tube you can get a lot of the accuracy back. I use a low density screen by saxon PC and it works very well. I get 99-101kPa at WOT on the road.
Attached Thumbnails Whats the point of an LS7 MAF?-maf-front.jpg   Whats the point of an LS7 MAF?-maf-back.jpg
Old 05-21-2013, 08:08 PM
ScarabEpic22's Avatar
99-02 PCM swap might help with that, EFILive's 97-98 LS1A support isnt as detailed as the 99-02 stuff.
Old 05-25-2013, 08:07 PM
decipha's Avatar
I use the screen door material that can be had at Lowe's or home depot, works great at straightening out the maf
Old 05-25-2013, 09:28 PM
T/A KID's Avatar
Helped do a buddies setup, 5inch tube/Ls7 MAF no screen/50%scaled, drives great.
Old 05-26-2013, 07:28 AM
ctd
ctd's Avatar
I'm trying to solve a slight bucking issue, would this screen shot be an example of a large MAF?
Old 05-26-2013, 02:41 PM
T/A KID's Avatar
You don't have anything referencing MAF Hz, so no one can help you
Old 05-26-2013, 03:10 PM
ctd
ctd's Avatar
OK MAF in fequency added. Please comment.
Old 05-26-2013, 06:37 PM
T/A KID's Avatar
Looks like its a bigger 4inch tube considering the Hz is around 3000 at 1700rpms. Ive never had problems with bigger tubes, however the tube shifts the MAF frequency to the left and with a bigger tube the MAF numbers need to be increased down low.
Old 05-26-2013, 06:50 PM
ctd
ctd's Avatar
It is a 102 TB with LS3/7 MAF in a 2001 C5 & yes a bigger tube.
I don't understand this comment?
"however the tube shifts the MAF frequency to the left and with a bigger tube the MAF numbers need to be increased down low"
Old 05-27-2013, 01:30 AM
T/A KID's Avatar
Say a setup with a 3.5inlet idles at 3000hz at 8 g/sec and at 2300hz that number may be 5g/sec. If you use a 4in inlet or larger it shifts the Hz to the left or down. So placing a 4inch tube on that setup would require the MAF to be adjusted so if a 4inch inlet idles at 2400hz 5 g/sec is not enough if the engine needs 8g/sec.
Hope that makes sense.
Quick Reply: Whats the point of an LS7 MAF?
