High clutch pedal?
Old 05-23-2013, 09:53 AM
a327vette's Avatar
Default High clutch pedal?
Just replaced the clutch in a friends 2000 T/A. It had a spec stage 1 in it, replaced with stage 2. It already had a tick master cylinder, i put a new slave cylinder and tick remote bleeder in it. The clutch engages fine, but the pedal is really high where it engages. I could adjust the master, but it just moves the location of the pedal, doesnt change the fact that the engagement is at the top of the travel. We did not use the spacer behind the slave, that would only make things worse.
The pedal was high before we replaced the clutch, so it isnt anything caused by the install.
Any ideas?
Thanks
Old 05-23-2013, 12:23 PM
TheBlueKnight's Avatar
I saw someone else asking about this in another thread. Few people said it was normal. I have a Tick Master and no matter where I adjust the pedal, just like you, the engagement is always at the top of the pedal.
Old 05-23-2013, 01:29 PM
a327vette's Avatar
Ok, thanks. I have a spec 3 in my lt1 and it feels completely different. I just wanted to make sure I wasnt missing something.
Old 05-23-2013, 01:41 PM
SPEC-01's Avatar
Generally speaking engagement will be slightly above mid-pedal. That being said, did you replace the entire assembly or just the disc?
Old 05-23-2013, 01:57 PM
a327vette's Avatar
I put the complete assy in it and had the flywheel turned when it was apart. It seems to apply ok, just much higher than what I am used to.
Old 05-24-2013, 09:42 AM
SPEC-01's Avatar
What were your measurements when checking for the need of the shim?
Quick Reply: High clutch pedal?
