Fuel Inj cleaning in Pics
Those bottles of fuel injection cleaner that cost from 2.99 to 20.99 only do sooooo much !!!!
Best to clean your injectors like a pro ................follow along
can of 3M inj cleaner PN 08956 and 3M FI cleaner hose PN 08917
you pull the fuel pump fuse so the fuel pump will not operate while the cleaning process is occurring.........the FI cleaner contains fuel to run the car at an idle speed as well as the concentrated cleaners.......when done with the cleaning replace the fuse so the pump will operate normally
i have seen the hose for cheaper....and i bought mine at NAPA for 40$.........if you figure you pay 100$ to have a shop do this.......how much did you save?
and after a cleaning you sure DO feel a difference.......i use the pour in the tank cleaners all the time and they do not compare to this
