Cherokee box into A-body
Old 05-23-2013, 08:48 PM
rlgood's Avatar
Default Cherokee box into A-body
I know this has been discussed several times but I would like to know if anyone can tell me what years of jeep cherokee steering boxes are used in GM A bodies, and if it is certain models like just Cherokee or Grand Cherokee or both. I am building a '71 Chevelle. Thanks
Old 05-23-2013, 10:28 PM
67Skylark's Avatar
My was from a 95 Grand Cherokee, I did find a list of years on this site but belive it had to be a Grand
Old 05-23-2013, 10:58 PM
1989GTA's Avatar
Mine was a 1998 Grand Cherokee. Like above I believe it has to be a Grand. I think the years are form 1993-1998. Maybe 1992.
Old 05-23-2013, 11:20 PM
1964SS's Avatar
It needs to be from a Grand Cherokee. Here are the Alpha codes you need to look for. I picked mine from a 1998 model for $40.
1992.5-1993 Alpha code AL or BT
1994 Alpha code AL, BT, or PD
1995 Alpha code JH
1996 Alpha code KD
1997-1998 Alpha code WK or BT
The alpha code can be found on the sticker on top of the box. If you get it from a yard be sure to get the mounting bolts with it.
Old 05-24-2013, 01:22 AM
Chocolate Apocalypse's Avatar
'98 Grand Cherokee here
Old 05-24-2013, 02:28 AM
sprinkfitter's Avatar
look up hemmings.com search quick ratio steering box there is an article with a complete list of years of vehicles and the ratio that will interchange with the A body.
Old 05-24-2013, 06:30 AM
ART T's Avatar
I put one in my 65 Sportwagon. Best bang for the buck. I went to the pick and pull and looked for the one with the lowest milage.
Old 05-24-2013, 07:15 AM
krwyellowZ28's Avatar
Mine is from a 1995 Grand Cherokee, but I believe 1989GTA has the right year range. Three bolts and sawzall to cut the 2 lines and adjustment sleeve and I had it on the ground in less than 10 min.
Old 05-24-2013, 08:30 AM
darksider's Avatar
Yeah, the 92-98 Grand Cherokee is the way to go. I'm pretty sure you have to get a rag joint from a 75 Nova. Interestingly, the box also fit in my 68 Bonneville.
Old 05-24-2013, 08:54 AM
Project GatTagO's Avatar
Received 1,389 Likes on 878 Posts
Does the JGC box use the metric o-ring style fittings?
Andrew
Old 05-24-2013, 10:12 AM
garys 68's Avatar
Yes, you can use a mid 80s G body hose with the truck power steering pump and jeep box. No adapters or modifications needed.
Andrew
Old 05-24-2013, 01:04 PM
psi3000's Avatar
Think mine was from a 97 Leardo . Use 85 Monte Carlo hoses. They fit right on. I think on the return side I used a 96 Ford astro van hose.
Old 05-24-2013, 03:36 PM
jwatts's Avatar
Andrew
Yes. The hoses from my Cherokee pump fit it perfect in my 66 Chevelle.
Old 05-24-2013, 06:03 PM
I was able to bend the original Z28 PS lines (1999 f-body LS1 and front accessories) to work with the JGC box.
Old 05-24-2013, 10:27 PM
rlgood's Avatar
Thanks for the info all!
Quick Reply: Cherokee box into A-body
