I don't understand MAF and 98mm
2000 WS6 - The entire car is stock except for Magnaflow catback. I want to start modding, and a new lid seems like the easiest way to go.
I can't buy one until I understand what a MAF is. And I've seen different sizes (98mm, 92 mm) but I don't know what size I need. Can anyone clear this up for me?
MAF is the Mass Air Flow Sensor. Its the part that is right before your throttle body. You don't want to change this or you will need to have your car re-tuned. SLP makes a nice lid that is 78mm. For reference. The sizes that you specified before is the size of the openings that are on the MAF. You want to match your lid size to the same size as your MAF (Stock is 78mm). Hope that helps.
If you do a 90mm TB you will want to get a bigger MAF and Lid. This way you are not restricting your flow. Again, the air and flow is only as good as the smallest entry point. Make sense?
Moderator
Yes you would be fine. However, your flow is only as good as your smallest point. So if you buy a 78mm lid and still have a stock 78mm MAF, your 90mm TB wont do anything. When doing these kinds of mods you have to match the components accordingly.
a fluid. Choke-points add flow resistance, but not a hard
limit to airflow. If you have good tapers in and out that
keep the flow laminar, then the effect of a small length
of less cross-section is minor. So is the benefit of one
oversized piece in an otherwise uniform tract.
Sticking with stock pieces until you know better, for
certain, will surely save you money. Everybody wants
to sell you something. Take it slow until you get past
the hype.
This is not really true, because air is compressible and
the hype.
the hype.
I ran my car in the high 11's with a stock lid, MAF, and TB with a baby cam only combo, thru an auto with a 4000 stall and stock 3.23 gears. With that said, if I were you I would just keep the stock pieces for now until you start to make some serious power.
