no fuel pressure
Old 05-25-2013, 10:18 PM
ws6wannab's Avatar
Default no fuel pressure
my car has been not running for 3 years now that its back togeather im having trouble getting fuel pressure the car started right up the first time i cranked it up ran then died not sure if it was due to my new large cam and i tryed to start it again and it wont start the fuses is good the tank was near empty when it was sitting and i didnt add fresh gas and i cannot hear the fuel pump kick on i tryed adding fresh gas and still nothing could i have killed my fuel pump from it sitting is there any way to tell short of replacing the pump and if i do have to replace the pump what would be a good upgrade
Old 05-27-2013, 07:06 AM
Blackpanther99's Avatar
Have you replaced the oil filter recently? Maybe the pump isnt having enough voltage which will cause low fuel volume.
Old 05-27-2013, 08:16 AM
HCI2000SS's Avatar
Well if the pump was not sucking any fuel due to the tank being near empty you may have fried the pump possibly. I'd start with a voltage test and go from there
Quick Reply: no fuel pressure
