Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
best performance trans for 700-800hp turbo zo6
Old 05-27-2013, 08:11 AM
princerobert1's Avatar
Default best performance trans for 700-800hp turbo zo6
Just wondering what the best aftermarket t56 for a dd c5 zo6 turbo car with 700-800hp.I go to the drag strip very often. Also im on a budget so im looking for something under $3000 if possible. I really wanna try and get the transzilla t56 magnum but its expensive. i would love to hear what everyone else is running in there high hp turbo/supercharged cars and what you guys paid for them.
Old 05-27-2013, 04:16 PM
V-seriesTech's Avatar
I ran a stock T56 for years. Companies are out there to make them without a doubt better, even as strong as TR6060's. All come at a cost, no matter how you look at it. I ended up splurging and getting a TR6060 and new C6 diff/cradle assembly. two reasons, I wanted a better layout, I think the C6 diff setup/mounts are more solid/stable compared that to a C5(2 bolts rear mounted vs 4 side mounted). Second, I did well on a stock trans before, a stock 6060 has done wonderous things at some crazy power levels plus,...getting the ZR1 spec my 6th gear is useable.
Anywho, a local shop here will rebuild a trans for probably less then that but it all depends on upgrades. Things get expensive quick.
Old 05-28-2013, 09:33 AM
ysb02's Avatar
Just get a strong output shaft in it and shift it smoothly. You'll have to upgrade to the T6060 like stated to get any decent strength increase. It takes $$$$ to do the t6060 btw.
Old 05-28-2013, 10:34 AM
will82's Avatar
Location: Somewhere Between Mild Insanity and Complete Psychosis
RPM All day.
http://www.rpmtransmissions.com/#!__master-page-1
Old 05-28-2013, 01:56 PM
yeah i been looking at rpm but if i can ever get in touch with eastcoast performance corvettes it sound like they would be the best bet for the power i should be making. They turn your t56 into a tr6060. Any of you guys know anyone running the transzilla t56 magnum?
Old 05-29-2013, 11:36 AM
ysb02's Avatar
iirc the magnum is just a name for the t6060.
Old 05-30-2013, 08:36 AM
thanks for clarifying that for me i was reading an artical and i got kinda confused. So question would you say sense the magnum is a tr6060 to get the east coast corvette tranny. What they do is take your t56 put tr6060 guts in it (make it a magnum). Then the add all the performance upgrades from tremecs tr6060. I think it would be stronger that way but i dont know trans i could be wrong.
Old 06-13-2013, 09:26 PM
lbm13186's Avatar
has anyone used one of these east cost corvette trannys????
Old 06-19-2013, 01:40 PM
smurfkiller's Avatar
talk to jeremy at rpm trans tell him what you are building he will help you get what you need.
Quick Reply: best performance trans for 700-800hp turbo zo6
