HELP!!! LT1 Problem after TB BYPASS
Old 05-27-2013, 03:42 PM
claudiel19's Avatar
Exclamation HELP!!! LT1 Problem after TB BYPASS
newbie who needs help, just finished the throttle body bypass and when I turned the car on I had the service engine on, I went for a little spin and I noticed that when I switched from park to reverse the car slammed and the same thing happened when I switched to drive. Then when i decided to put my foot down it was NOT responding as usual, I could not feel the pull. Help I am wondering if it is my optispark, like if I spilled coolant on it or on something else.
Old 05-27-2013, 05:11 PM
shbox's Avatar
First check to see if you unplugged something and did not plug it back in. Plus, you should see what the trouble code is.
Quick Reply: HELP!!! LT1 Problem after TB BYPASS
