coolant crossover
Old 05-28-2013, 09:56 AM
89_camaro's Avatar
Default coolant crossover
using fbody radiator and water pump... do I have to run the crossover tubes to the top of the water pump and drill/tap the housing or can i run a line from the crossover to the radiator just below the over flow outlet near radiator cap
also on the radiator there's a outlet in lower drivers side, what is that for can I just block that off
Old 05-28-2013, 10:45 AM
soundengineer's Avatar
stock configuration is four corners go to the return on the Radiator
I made my own to go with my setup and all of my nitrous plumbing that goes under the intake
Old 05-28-2013, 10:46 AM
Old 05-28-2013, 11:28 AM
Rick Speed's Avatar
Yes that will work fine. You have a lt1 radiator and that extra port just gets plugged.
Old 05-28-2013, 03:20 PM
bczee's Avatar
Soundengineering, what did you do to connect to the F-body radiator steam port ?...
If you have a late 4th Gen Radiator.. then I would just hook it up to the stock location on the Radiator.. you might need to adapte the different size port/hoses as they are different size on the radiator and crossover tube.
As other stated, either way will work (radiator or WP).
BC
Old 05-28-2013, 03:48 PM
89_camaro's Avatar
thanks for the quick reply glad to know there away around drilling a more or less unneeded hole
Quick Reply: coolant crossover
