Jegs Hobbs switch wiring
Ok, I would wire it Normally Open using neg ground on the common screw of the hobbs switch and then the "NO" on the hobbs switch would go to the negative posistion on the signal wire for the relay.
To set the hobbs switch I regulate my shop air pressure down to the desired PSI (5psi here) and adjust the allen screw on the hobbs switch that way using a multi meter to set the on/off of the hobbs switch.
Hope that jibberish makes sense.
I'd text ya but my phone died lol. I have mine setup on the negative wire on the relay so when the hobb switch activates it grounds out the relay/relays. I would get it as close to 1psi as possible. 5# can show a fuel spike in your fuel maps when trying to tune the car. What I did was blew into the line that runs from my vaccum source to the hobb switch with my mouth. Just a lite blow of air in the line to where to hobb switch activates the secodary fuel pump is what you want. There should be a rubber cap on top of the hobb switch that you remove and there should be a allen headed bolt that you can screw in and out to adjust the pressure it activates. Its spring loaded so the more you back the bolt out the lower the pressure it activates on. Good luck
