408 windage tray clearance problems?
Old 05-28-2013, 07:14 PM
Loudpipe's Avatar
Default 408 windage tray clearance problems?
Was putting the pan on my 408 ready to put it in the car, gave it a spin a it stopped. Looks like the rod bolts are hitting on the windage tray. How much do you need to cut out? Anyone else had this problem? And what remedy did you use?
Old 05-28-2013, 07:31 PM
leeluther252's Avatar
You don't need to cut, you need to use spacers. (washers).
Old 05-28-2013, 08:19 PM
DietCoke's Avatar
Use washers to space it out, or just buy a proper windage tray. I have a mast black label tray on mine. ~$60 and clears up to a 4.250 stroke. Nice piece.
Old 05-29-2013, 10:22 PM
Loudpipe's Avatar
Washers did the trick....sometimes common sense is over looked. Thanks again
Old 09-29-2015, 11:10 PM
zeusrotty's Avatar
I have the mast tray on my car and it didn't do the trick.
Old 09-29-2015, 11:11 PM
blk00ss's Avatar
Jesus Christ. Did you just spin the motor over as hard and fast as you could trying to clearance it?!
Quick Reply: 408 windage tray clearance problems?
