Thread size of drain plug for T-56? 1/2in NPT?
Old 05-28-2013, 08:25 PM
X-ray's Avatar
Default Thread size of drain plug for T-56? 1/2in NPT?
Is it 1/2 inch NPT? It's been 2 years since I changed the tranny fluid, and if I remember correctly the plug is not magnetic, so I would like to add this:
http://shop.advanceautoparts.com/web...tic+drain+plug
Also, anyone know where to get a magnetic drain plug for the 10 bolt differential? I think it's 1/4 inch NPT, and I thought someone said to go to a lawn mower store. I'm thinking about checking NAPA since they're usually more knowledgeable than Advance Auto.
Old 05-29-2013, 09:17 AM
calhoon's Avatar
This is a 1/2 -14 NPTF plug.
BTW
The T56 already has two magnets inside.
Old 05-29-2013, 05:02 PM
X-ray's Avatar
Thanks. So the magnets are strong enough that they don't need cleaned off? Because I don't even know where they are, so they must only be accessible when you're rebuilding it.
Old 05-30-2013, 01:50 PM
calhoon's Avatar
It hard to clean them fully with the trans disassembled....no you can't clean them easily. They are trapped between the extension & maincase housings...at the bottom.
Quick Reply: Thread size of drain plug for T-56? 1/2in NPT?
