Water
Old 05-29-2013, 08:49 AM
Transmarrowbird94's Avatar
Default Water
Probanly is not the right spot for this but I have a 94 ta with t tops when I bought the car I was told they did not leak... We had a bad rain storm last night I opened the door today and water all on drivers side foot all the way to the back seat I felt the head liner and it was dry where else could I come from?
Old 05-29-2013, 09:12 AM
Stroked96Bowtie's Avatar
Close the car up, run the water hose over the top of the car while peering into the window. Sounds like its on the drivers side somewhere for sure.
Old 05-29-2013, 09:57 AM
fbody_brian's Avatar
is it the back floorboard area?
I've had this happen and it's because of my hatch weatherstripping.
Old 05-29-2013, 09:59 AM
BoostedDSM's Avatar
Both my Ttop cars leak in the front corner where the top meets the a pillar, check there and then in the back close to where the top edge of the window starts to go down in the back. I'll be doing new seals on mine over winter as both sides leak under high pressure but nothing else.
Old 05-29-2013, 10:09 AM
Village Troll
SS RRR's Avatar
Most common areas for leaking is worn out weather stripping on the hatch and t-tops. If the car was ever in a wreck that could play into it as well.
Quick Reply: Water
