Any issues w/replacing a LS1 oil pump w/LS6
Old 04-26-2004, 10:54 AM
TRYMYZ's Avatar
Default Any issues w/replacing a LS1 oil pump w/LS6
I have a 98 Z28 and I am looking to replace my oil pump. Is the LS6 pump a direct replacment or is there some fabricating that needs to be done ? For those who have done it, why kind of pressure increases did u see ?
Old 04-26-2004, 11:06 AM
PongoX11's Avatar
Direct Replacement. I personally went with a Ported LS6 from Thunder Racing. 5-10psi higher, I went with it more for the reliability of buying a new pump when I did swaped cams
Old 04-26-2004, 11:28 AM
Motorboater
SilverGhost's Avatar
i have the ported ls6 from thunder as well, works great
Old 04-26-2004, 12:17 PM
WILWAXU's Avatar
It's a straight forward swap. Took me about 15 mins. Figure 2 hours for you
Get the oil pan as low as you can, don't loose the o ring between the pump and the pick up tube. Call me if you have any issues
Old 04-26-2004, 02:30 PM
TRYMYZ's Avatar
Thanks for the info guys. Looks like thats what I will be doing this weekend.
Old 04-26-2004, 02:40 PM
HumpinSS's Avatar
Do you have to lower the pan if you are swapping the cam at the same time
Old 04-26-2004, 06:05 PM
WILWAXU's Avatar
Lowering the pan just makes it easier to get to the bolt that holds the pickup tube on.
BTW.. gearwrenches are your friends
