PCM tune ?
Old 05-29-2013, 05:53 PM
gmcyukon's Avatar
Default PCM tune ?
Did a full rebuild and did a cam install and other supporting mods. When I did a first start. I got the " reduced engine power " message. Ppl said a tune would fix that
Old 05-29-2013, 06:54 PM
LSX Power Tuning's Avatar
What kind of vehicle?
Old 05-29-2013, 06:55 PM
BLK02WS6's Avatar
What do you mean when you did a first start? just starting the engine up gave you the message? Yes, a tune is needed to prevent going into reduced power mode, but it shouldn't come in just starting it up...
Old 05-29-2013, 08:50 PM
gmcyukon's Avatar
Gmc yukon 2wd 5.3
Old 05-29-2013, 08:55 PM
gmcyukon's Avatar
I started the vehicle for the first after the rebuild. It said in my message center reduced engine power.. And I won't even idle at all. Can't even get the rpms up past 2 grand I have video I can post
Old 05-29-2013, 10:40 PM
I agree, a tune is needed but the reduced engine power shouldn't happen at idle. Double check and make sure you got everything plugged back in, maf, tb, map, etc..
Old 05-30-2013, 12:17 AM
gmcyukon's Avatar
I just remember I don't have the maf on my cold air intake
Old 05-30-2013, 07:33 PM
BLK02WS6's Avatar
Your IAT sensor is in there, you kinda need that...
Old 05-30-2013, 09:53 PM
gmcyukon's Avatar
I got the MAF on. Started the engine no reduced engine powe light but once the motor warmed up reduced engine light came on it it idled at 500rpms and stayed after mild revs
Old 05-31-2013, 04:56 PM
BLK02WS6's Avatar
Are you sure everything else is plugged back in? Did you change the injectors, or are they stock?
Old 05-31-2013, 05:09 PM
gmcyukon's Avatar
Everything is plugged back in! Injectors are stock Flex fuel injectors
Old 05-31-2013, 08:00 PM
BLK02WS6's Avatar
You are going to have to get a scanner on it to find out - hard to diagnose something like this over the internet... you got a weird one...
Old 06-04-2013, 01:05 PM
gmcyukon's Avatar
I got the code
Old 06-04-2013, 02:29 PM
Have you messed with the TB or idle set screw?
Old 06-04-2013, 03:13 PM
gmcyukon's Avatar
I have an electric tb
Old 06-04-2013, 04:26 PM
Sounds like the pcm is trying to make it idle setting off the IAC code. I just looked through a few random DBW 5.3's I tuned and all of them still had P0507 settings left stock. I havent had that code pop up before but I also never tried running one untuned.
Old 06-04-2013, 04:55 PM
gmcyukon's Avatar
So basically once I get a tune? This issue will be fixed or should I get another IAC
Old 06-04-2013, 07:41 PM
BLK02WS6's Avatar
DBW doesn't have an IAC - it opens the blade vice haveing an IAC motor... that is a generic diagnostic readout. I would say a tune to get it to idle properly should get rid of your issue. Like LSX power tuning said, I've never even started one up with a cam and no tuning - I always do a base tune to get started - so I can't say I've ever seen this exact problem...
Old 06-04-2013, 08:26 PM
gmcyukon's Avatar
Ok so will the tune get rid of my reduced engine power light
Old 06-04-2013, 10:08 PM
Best guess is yes, but without any kind of data log or anything to go off no one can guarantee that a tune will fix it.
Quick Reply: PCM tune ?
