New PB
New PB
This is one of my runs from last weekend. This last winter had heads ported and put a super vic on. Took it to the dyno and dialed it in.
Ran 10.54 @128. Think it should be in the 10.40's. Am changing to
3.89's in the back. This run was on a 250 shot. 200 off the line and 50 in at 1 second.
Also am looking into changing cams. Need more durration for mid range and top end.
Hope everyone is getting some great runs in.
Well I just got back from the track and went alittle better. We got the 3.89s in and went 10.47 @ 130 and a 10.46 @ 129. Still spinning pretty bad off the line. Going to set my controller for 50% off line and the rest at 2 seoconds. hopefully that will help.
You bet faster is better............Just got some double adjustable coil overs in , so will be installing those as soon as we can. That should help to keep it from unloading so quick. won't solve the whole problem till I get the front coil overs. But dang they're so expensive. At the end of year when I get my vacation money I'll order my front Bogarts and tires then at tax time I'll order the front coil overs. That just leaves solid roller cam and lifters, rocker arms. Then I hope to be where I want to be ...........9.90's or so.
