what bolts for cat racing sfi flexplate
Moderator
Most SFI flexplates are thicker and you need longer bolts.
IIRC the stock bolts are only 12mm and you probably need 18mm.
CircleD sells a wide variety of converter bolts including ones from ARP.
I just use hardware-store 1cm (25mm) long fine-thread bolts with a 9.8 or 10.8 hardness. I add a very thick hardened washer (about 3mm) under the head. If doing this, first make measurements to ensure the bolt doesn't bottom out in the converter before it reaches full torque; allow about 1 fine thread for stretch.
Update - This is for flexplate to converter. Not what you wanted.
