Powerbond Mounting Depth
Installed my 25% UDP a couple of weekends ago and all seemed good. Haven't driven it since then until today other than backing it out of the garage to wash this weekend. On both of these occasions the belt was squealing. (not like crzy, but clearly audible) My concern is that i did not get the pulley far enough onto the crank. I went to AllData during the install (they list all factory specs and procedures) and the instructions said to make sure that the nose of the crank is recessed with between 2.4mm - 4.8mm left exposed of the inside of the pulley. Basically, crank the pulley down until the crank is 2.4mm - 4.8mm away from being flush with the face of the pulley then stop. I got it right about in the middle using a grade 8 threaded rod, washer and nut with a half inch bar and a 3 foot piece of pipe for more leverage. I cranked until i didnt feel safe anymore, and in the middle is where i ended up. (about 3.0mm left before i was flush) Is this still the correct procedure for a PowerBond pulley? Should it be flush? The belts seem to line up well visually. What are the correct depth specs? Would be nice if PowerBond supplied this with their pulley.
It's not mine! woo hoo!
Here's a pic I took when I did the install:
Here's my build thread where I posted about it: https://ls1tech.com/forums/17235917-post29.html
Thanks for the help guys. I did something ingenious (God I want to kick myself sometimes) when I was leaving work last night ---- i turned the ac off. Boom, no more belt squeak. Looks like the main belt is OK. So yeah, I agree with the theory that maybe the ac tensioner has had it, given the fact that it is the exact same part that is on my 2000 5.3 silverado and I have changed that due to failure twice. Thanks again guys.
Edit - it was squeaking again this morning with AC off, so the main belt is has an issue too. Once it warmed up it went away, so I am assuming that the belt is expanding with the heat a tad and is helping it grab better. Tensioners might be the cause, but I am more and more suspect of the belts that came with this kit....
https://sdparts.com/index.php?q=deta.../kpbu1480-ss25
...Never heard of MasterPro. Changing the belts out with some better ones would be a good starting point, it just sucks because i bought the above kit because of the price. If it needs better belts then Im gonna feel ripped off. Thats an easier and cheaper experiment than the tensioners. And demonspeed, you are right that the car is 11 years old, but it only has 32K miles on it for whatever thats worth.
I just googled the main belt part number. Description is as follows...
Detailed Description
Designed for the budget conscience customer who wants quality, but does not require the superior performance of the premium belt.
Manufactured with first-generation belt materials.
Not for severe driving or high load applications.
Meets SAE J1459 specifications.
Well its seen 6K+ RPM a few times already. Is that "severe driving" or "high load"? F!F!F!F!F!F! get what you pay for i guess.
I'm happy with my Goodyear Gatorbacks. While pricier than normal, they've been just fine. They were also the go-to belt long ago before everyone jumped on the Gates bandwagon.
4060763 (main) 40407378 (a/c). You can cross reference those numbers to any belt company of your choice. I found those Goodyear numbers cross referencing the belt recommended from powerbond.
I've had the best luck with the Goodyear Gatorback belts, they're my preference over the Gates belts.
https://ls1tech.com/forums/8606459-post34.html
Thanks guys. Given the fact that BOTH belts squeak and I feel that I got the pulley mounting depth right I think I will try changing the belts first. The chances of of both tensioners and/or their pulleys going bad at the same time seems pretty slim. I'll let you know if changing belts solves the problem because if it does then buying the pulley, belts and bolt as a kit would not be the way to go. We shall see.
