Couple Diablosport Intune logs
Old 05-30-2013, 10:55 AM
SRTmike's Avatar
Default Couple Diablosport Intune logs
Finally got time to play with the Intune on my '06 base LS2 A6. Here are some logs I made. During run 1 and 2 the WB02 was dancing 12.4-12.8.. on the 3rd gear pull it was 13.00 then around 4000-4500 dropped into the 12.8 range. looks like a little too much knock.. I loaded the diablo tune. Going to the track tomorrow so open for ideas, etc
http://www.2shared.com/file/hOHZcN8V/run_1.html
http://www.2shared.com/file/nJRsGvux/run_2.html
http://www.2shared.com/file/78sPxdk1/3rd_gear_pull.html
Old 05-30-2013, 11:37 AM
LS1Tech Sponsor
Mike@Diablosport's Avatar
Any mods on the car?
Looks a little lean, might add a little fuel in the 4-4.5K RPM range, that ought to help quench some of the KR as well.
Old 05-30-2013, 01:30 PM
SRTmike's Avatar
Yup.. Vararam and X pipe and mufflers.
Old 05-30-2013, 02:52 PM
LS1Tech Sponsor
Ahh, yeah, the Vararam will help lean it out a bit, add some fuel and check it again
Old 05-30-2013, 03:22 PM
SRTmike's Avatar
i plan on making a pass, add 5% or so and making another.. hopefully the knock will do away and the MPH will go up.. bristol is a slow track DA is already 3000ft..ugh
Quick Reply: Couple Diablosport Intune logs
