lsa head has blocked off vapor/steam hole... why would that be
I purchased these heads from another member on the board and never realized this until now. Heads are brand new, why would this be
Possibly internal waterways are different and less susceptible to airlocks at those locations.
I'd still be inclined to drill it out and use them though unless you were sure of the above.
IMO it isnt difficult to use them and it makes sense to do so.
7 Second Club
It's cheaper to use an insert like that than to use the external bolt and plug like on the earlier heads. They still only block off the rears and leave the front open for the crossover, etc. You have to knock it out with a hammer and punch while the head is off though as it comes out the bottom and not through the top if you want to join the steamports all together.
