416 LS3, Mast Black Label CNC heads & 2pc CNC intake, dry sump, 14:1, Complete
Category: Accessories
Price: $11500
Location (State): MO
Item Condition: Brand New
LS Engine?: Fits LS Engine
Pictures are current.
Selling COMPLETE only. No Part Out.
Has run 9.10 @ 148 mph - 2950# Normally Aspirated, never sprayed. During the freshen it was set up for spray (300+HP hit). Engine makes 775HP at flywheel, no NOS. Never sprayed.
Just completely freshened, many NEW parts.
NEW valve job (lightly trued & lapped), NEW valve seals, NEW Manley beadlock keepers, NEW surface mill on heads (light cut), 64cc chambers.
NEW PAC 1226 valve springs.
NEW Comp Cams solid roller lifters.
NEW Cloyes 'Z' Timing Chain
NEW Clevite competition main bearings
NEW Federal Mogul competition rod bearings
NEW Federal Mogul HD Babbit cam bearings
NEW Total Seal AP steel rings (file fit for N20 use).
NEW torque plate hone and ring fit.
NEW Felpro MLS head gaskets.
NEW ARP Main stud set - late design.
NEW crank micropolish.
NEW Accufab 4500 TB, MAST fuel rail kit, and Fuel Injectors.
Engine is in great shape and ready to go. 2300.00 in parts just to freshen.
LS3 block with bronze .842" lifter bushings, 4.070" bore
Callies Dragonslayer 4340 crank - 24X reluctor
Howards 4340 billet I-beam rods
Diamond custom gas ported N20 pistons (14.1 with a .053")
Mast LS3 Black Label medium bore CNC heads (hollow stem intakes, Ti retainers, severe duty stainless exhaust valves, PAC solid roller springs)
Mast 2pc LS3 4500 flange intake CNC ported
Comp Cams custom roller cam (27X/28X @ .050), 773"/748"
Comp Cams roller lifters
Comp Cams 3/8" heavy wall pushrods
ARP Pro Series head and main studs
T&D lightened and roller bearing tip 1.7 shaft rocker set up
Dailey 2 stage scavenge dry sump belt drive pump and drive mandrel
ARE cast dry sump oil pan
1.5 gallon aluminum dry sumptank
ATI Super Damper
Accufab 4500 TB w/ tb bracket
Mast fuel rail kit
Siemens 72# injectors
Moroso aluminum fabricated sheetmetal valve covers w/ locators
Complete intake to pan. Motor plate, alternator not included. Build sheet with all build specs included.
11,500.00
Serious only please. Shipping available.
BRAND NEW Kooks 2" F-Body (NEW design header available)
additional 875.00 (not available separately)
Contact Tim - PM, text or call
314.452.6639
Prefer pick up - can ship
