fuel sensor for Holley hp controller
Old 05-30-2013, 10:37 PM
superstreeter's Avatar
Default fuel sensor for Holley hp controller
Im hooking up a Holley HP controller. I want to run the fuel sensor with the harness they supply,,,,Does anyone know if GM makes a fuel or oil sensor that will have the same hookup with a 1/8th npt thread to tap into the fuel rail ???
I believe the fuel sensor would work with the oil sensor plugged in ???
Old 05-31-2013, 12:22 AM
gnx7's Avatar
I run the Holley 0-100psi sending units on my HP system for fuel and oil pressure. Works great.
Old 05-31-2013, 07:44 AM
Im trying to save a buck,, or a hundred in this case, lol. if I can find a GM one !!!
Old 05-31-2013, 08:40 AM
skinnies's Avatar
Just suck it up and buy the holley sensor, even other brands 100psi sensors are expensive.
Quick Reply: fuel sensor for Holley hp controller
