slave cylinder bore size ?
Old 05-31-2013, 04:42 PM
1 FMF's Avatar
Default slave cylinder bore size ?
what is the slave cylinder bore size, specifically the square area of the concentric ring that the hydraulic pressure of the brake fluid applies to?
I want to calculate slave throw out distance that you get with various clutch master cylinders.
Old 06-01-2013, 10:03 PM
1 FMF's Avatar
fwiw i measured an autozone #13207 slave.
since it's concentric, the inner diameter looks to be 3.64 cm. the outer diameter between 4.7 and 4.8 cm. calculated area is 7.314 cm^2.
Old 06-01-2013, 10:10 PM
1 FMF's Avatar
so now my question is, are the slaves of different years a different size ?
Quick Reply: slave cylinder bore size ?
