all i want to do is log my wb
Old 06-02-2013, 12:27 PM
bad6as's Avatar
Default all i want to do is log my wb
ive tried to log my wb. its a aem ugeo and i have it on the egr wire. i turned on the egr in the pcm. i created a config on the table
name. air fuel rairo
abbrv. afr
senor. egr position
units. afr
function. [PID.2810]/.5+10
when i hook up to the pcm and start logging it says its unsupported parameter
attached a log from this morning
File Type: hpl
Old 06-02-2013, 01:04 PM
Tally TransAm's Avatar
i use pid.2811
and change sensor to "none"
Old 06-02-2013, 06:42 PM
bad6as's Avatar
ill give that a try, thanks.
any idea how to log a 3bar map in to psi
Old 06-02-2013, 07:40 PM
bad6as's Avatar
([PID.2334]-101)/(101/14.7)
using that for the 3 bar conversion to log boost. seams like its accurate
Old 06-03-2013, 10:31 PM
bad6as's Avatar
Still dosent work tally. Shows unsupported still
Old 06-03-2013, 10:53 PM
do you have "egr position (V)" in your table?
Old 06-03-2013, 10:54 PM
post your config file and ill take a look, but if your not logging "egr position (v)" thats probably the issue
Old 06-04-2013, 07:39 PM
bad6as's Avatar
i didnt but i just added it
Old 06-04-2013, 07:42 PM
bad6as's Avatar
scanner config
keeps saying file invalid email?
Old 06-05-2013, 06:22 PM
bad6as's Avatar
Well i got arf to work thanks all.
had to change pid to 2811 and also do the egr postion in v
Ill have to wait for my trans to get back so i can start it and the voltage .
now i have a 3 bar map sensor and i have it converted to read psi. Is there a way to get it to read only boost the function i have for it now is pid.2334-101/101/14.7. at vaccume it reads -psi but i rather just see boost on the chart.
__________________
Quick Reply: all i want to do is log my wb
