high compression 370
Hey guys I'm lookin at purchasing a 370 shortbock from TSP with 12cc dome pistons. Looking at using the PRC 2.5 5.3 heads but was wondering how much better off id be to get their as-cast 225 heads so I would have room to grow in the future? Both heads would be milled to 60cc. The car is an 85 cutlass 4 door and would be used mainly as a street car but will be fairly track capable.
Right. I guess I could always go bigger if I'm not happy with the 5.3 heads. I wasn't quite sure how much the bigger valves and 13* valve angle would be worth. Thanks for your input.
We have high compression 370CI short blocks with +10cc Diamond pistons, Forged rods, ARP rod bolts balanced, Polished, and chamfered core GM crank and blueprinted LQ9 seasoned blocks in short block form for $2959 with a 1 year warranty. We also have several options for heads that work great with the motors. Give us a call if we can help you with the build.
It will be 14:1 with a 60CC chamber. Please understand that it will probably need to be clearanced in the chamber of the heads with a head that tight. Give us a call and we can help you with the build.
Thanks for the info. I figured it would be pretty close. I'll be checking all clearances and re-checking since I don't really have the money to do this twice haha. Being 22 and trying to put a setup like this together probably isn't the smartest choice in the first place...
We are here to help you from the beginning to the end on your project. Take a look at our customer feedback on any forum, ebay ect. We will make sure that you get the right stuff and set it up right the first time. Let us know if we can help in any way.
Thank you. Its nice to have such a great site like Tech and people like you ready to help somebody out. Now all I need to do is round up a little more coin so I can pull the trigger on parts!
Could anyone give me some input as to which intake and carb to use? I am leaning towards the performer rpm intake with a HP 850 e85 carb. Still haven't decided on the heads, still looking at the PRC ported 5.3's or their as cast 225's. I'm looking for a really broad torque curve with the strongest low-midrange possible. Id like it to pull hard just past 6500 probably try and shift by 6700 and have the rev box set at 7k or so. This is obviously my first time doing this so any opinions are welcome, as is constructive criticism. Thanks again for the help.
pending heads and cam i would be looking at a super vic
