1995 4l60e issues
Old 06-04-2013, 08:06 PM
white3800camaro's Avatar
Default 1995 4l60e issues
I have put 500 miles on my fresh 4l60e, went to go put gas in it the other day after not driving it for a week or two and it started acting very odd. The transmission shifted into 2nd normally, then when it went to shift into 3rd it felt like neutral. If I manually shift the transmission starting in 1 it will go though the gears like normal. Transmission pressure is good will hit 200 in drive and 250 in reverse.
Any ideas?
It almost seems to be electric.
Old 06-05-2013, 11:45 AM
Moderator
mrvedit's Avatar
Any ideas?
I've seen similar posts where someone said they replaced the 2-3 shift solenoid and it fixed the problem. I don't see how that is a possible solution, but it might be worth a try. Another relatively inexpensive test would be to replace the pressure switch which I've read fixed somewhat-similar strange problems.
If you can shift into 3rd in [D3] then your 3-4 clutch should be fine.
If you have 1st and 2nd gear in [D4]/[OD] then your forward sprag should be fine.
(Please confirm those to be true.)
Beyond that, it might be sticking valve in the valve body.
Perhaps a more experienced person (and builder) like Dynamic396 has better ideas.
BTW - Glad you already know your line pressures. I assume there are not codes either. Also, here is a good chart for diagnosing trans problems:
http://forum.efilive.com/showthread....rence-Material
Old 06-05-2013, 02:44 PM
Nope, no DTCS. I will pull the pan and test the solenoid. The guy who built my trans put an adjustable pressure switch in it, has the goofy wire nuts splicing it in.
I can manually shift it 1-2-3-4 and 4-3-2-1 fine, if I put it in OD and try it 1-2 fine then acts up trying to get 2-3
Old 06-05-2013, 03:36 PM
Moderator
mrvedit's Avatar
I asked Dynamic396 and CarlsonAuto for help; CarlsonAuto researched it on the "Transmission Rebuilders Network Worldwide" and found this:
I trnw'd it, 2-3 shift solenoid, check ball capsule leak, torn 1-2
accumulator seal, incorrect o-rings on 3-2 solenoid were all similar
complaints and confirmed fixes. There is one with the exact complaint and a
confirmed fix. It was a blown lower v/b gasket.
Looks like I wasn't too far off; hopefully that helps.
Old 06-06-2013, 01:02 PM
Dynamic396's Avatar
Yeah, boy that's a strange one isn't it!
The only difference between 3rd gear in the OD position and manual 3rd is the overrun clutch being applied in manual 3rd. In a stock valve body, that doesn't even occur until the 2-3 shift is commanded and the 2-3 shift valve actually strokes.
The pressure switch manifold does send a signal to the PCM when D3 oil is present (manual valve in the manual 3rd position). It's possible that something is going on there.
I don't see how a 3-2 downshift solenoid could cause any of this. The 2-3 upshift is unrestricted anyway. All the 3-2 solenoid does is create an orificed bypass so the 3rd accumulator can exhaust faster and get the band applied more quickly in a low speed 3-2 downshift scenario. It shouldn't matter what position the 3-2 control valve is in on a 2-3 upshift.
I know that's not much help, but I think some exploratory surgery is in order. I'd pull the valve body and have a look at the gaskets as was mentioned...
Old 06-06-2013, 05:06 PM
Pulled my pan after work today, had some residue in the pan, seemed somewhat normal. My 2-3 solenoid is extremely loose in the valve body. Is this normal? It has a lot more play to it then the solenoid next to it.
When I turn the key on the 2-3 shift solenoid receives ground for a split second and clicks.
I removed the pcm and grounded the soleinod wiring to the transmission, the 2-3 and 3-2 both click when ground is applied.
Old 06-06-2013, 08:22 PM
Moderator
mrvedit's Avatar
I just checked an "old" valve body and didn't notice much difference in the amount of play between the two solenoids. So, I would say a loose 2-3 solenoid is not normal. It might just be the o-rings on the solenoid, but the solenoids are only $12 and any trans shop should have them. If you are near Ann Arbor, I have extra everythings. I also have extra solenoid o-rings.
If that doesn't do it, follow the advice and pull the valve body, but have some new gaskets ready. Was the separator plate replaced during rebuild? If not, get the Transgo Universal one ($25) and drill it; I can give you my recommended hole sizes.
Old 06-07-2013, 10:54 AM
I did the transgo one when I put the HD2 shift kit in it.
I will probably get a solenoid and try that, you can grab onto it and wiggle it up and down a lot.
Old 06-07-2013, 11:05 AM
72blownvert's Avatar
The 2-3 solenoid feels looser because it does not have the shift valve pushing against it like on the 1-2. Some wiggle is normal.
Old 06-09-2013, 10:00 AM
I knew it would be some what looser because there isn't spring tension on it. But I can move it in a circular pattern more then I can with one in an older VB I have laying around.
Quick Reply: 1995 4l60e issues
