Spal Fan people in here.....
Old 06-04-2013, 09:48 PM
I8UR4RD's Avatar
Default Spal Fan people in here.....
So I have a 16'' Spal Extreme with a shroud.
I heard someone say that I may have to put some sort of relay on it for fan speed or something for my 02 ws6.
Does this have any merit? I figure the thing would hit the set temp and kick the fan on full blast.
Is there more to wiring this thing up than just splicing it in to factory wiring?
Old 06-04-2013, 10:00 PM
TPIIROC's Avatar
I would think the factory fan relay and wiring should do the job.
Old 06-04-2013, 10:03 PM
I8UR4RD's Avatar
makes two of us...but I don't know it all by any means so I ask questions.
Old 06-04-2013, 10:12 PM
02LS1ram's Avatar
I wired mine into the factory harness. No problems what so ever with overheating during the summer, when I was procharged.
Old 06-04-2013, 11:02 PM
chejos13ls1's Avatar
The wiring on the fan should be just on/off,just splice the factory wires onto the fan and you should be ok.
Old 06-04-2013, 11:42 PM
studderin's Avatar
Ive been running a 16 spal for 2 years (PN 2053 I thtin? and its fine tapped into the stock fan1 wires. The stock wires the bigger then the spals, lol
Old 06-05-2013, 10:37 AM
11SECSS's Avatar
I have the dual 11" SPAL fan setup on my car and using the factory wiring also and have had no problems.
Old 06-05-2013, 12:04 PM
allout06's Avatar
weird. i saw a post awhile back and ppl were saying you need a seperate relay wired in. i have 2 fans to wire in. maybe that's the difference?
Old 06-05-2013, 12:28 PM
11SECSS's Avatar
I wired my 2 fans up just like the factory did even used the same wires and still have full fuction of the SLP manual fan switch to be able to control them without the car running.....It still has the factory relay that cam with the car.
Old 06-05-2013, 01:37 PM
allout06's Avatar
^ def good to know! maybe you could make a diagram for the wiring and post it?
Old 06-05-2013, 01:42 PM
ramairetransam's Avatar
i have my two spal fans wired up to the factory wiring and they both come on at once. No problems with it that way .
Quick Reply: Spal Fan people in here.....
