What timing chain do you have
Old 04-26-2004, 06:38 PM
HumpinSS's Avatar
Default What timing chain do you have
,did your ASP pulley need to be machined and are you running the stock or a ported LS6 oil pump. I am doing a cam swap in a week or two and I am getting all my parts together. I want to buy a double roller but I am not sure if that combination with an ASP pulley will cause me any problems. So to avoid any explicatives during the install I would like to verify FOR SURE before i plop the money down for nothing.
To my knowledge the spacers that are sent with the timing chain is what causes the pulley to have to be machined.
Old 04-26-2004, 07:22 PM
AnthonyR's Avatar
I'm using a rollermaster double roller with an ls6 oil pump and no machining to my asp pulley
Old 04-26-2004, 07:25 PM
HumpinSS's Avatar
Who did you purchase your pulley from
Old 04-26-2004, 07:28 PM
Neumonic2002's Avatar
When I did my cam swap I went through all the reservations your going through...
I stuck with the stock chain (car had 18K on it) and stock oil pump, if you have low miles and aren't going with a huge bump stick the stock stuff including retainers is fine in my opinion.
I decided to save the 400+ dollars on the items above for when I go with a bigger cam and potentially AFR heads next year.
Old 04-26-2004, 07:33 PM
HumpinSS's Avatar
I went with a FM13 230-232 car has 62K on it and I am going with new springs, retainers and the whole nine yards
Old 04-26-2004, 07:38 PM
JoeyGC5's Avatar
Did my Rollmaster double with the ASP pulley and no problems. The vettes need to watch out, haven't heard of any problems with the F-Bodies.
Old 04-26-2004, 07:44 PM
Kens_02SS's Avatar
Ditto and got my pulley from Thunder racing
Old 04-26-2004, 07:45 PM
jrp
SN95 Director
jrp's Avatar
no machinimg required on mine either; rollmaster doube, asp pully, ls6 pump
Old 04-26-2004, 07:46 PM
Mike94ZLT1's Avatar
I have the rollmaster single roller and its a great piece of work. I got it for $60 something from texas speed and performance, and I'm very happy with it.
Old 04-26-2004, 11:39 PM
HOTROD98Z's Avatar
Rollmaster dual chain, Ls6 oil pump and no problems with my ASP pulley either.
Old 04-27-2004, 10:00 AM
AnthonyR's Avatar
Got mine from Thunder as well...they even threw in a free bolt
Old 04-27-2004, 05:43 PM
pdd
pdd's Avatar
i have the double roller
Old 04-27-2004, 06:38 PM
Bink's Avatar
Cloyes Hexadjust - pricey but able to advance and retard easily. FWIW.
joel
Old 04-27-2004, 10:25 PM
Speed2k2z28's Avatar
I use the GMPP chain,and an asp pulley,stock oil pump
Brian
Old 04-28-2004, 11:04 AM
Deeavi's Avatar
SLP Double Roller with March Fluid Damper/Pulley and TSP ported LS6 oil pump No fitment problems
Old 04-28-2004, 12:26 PM
Kevyn's Avatar
JWIS chain, ls6 pump, asp pulley, no problems
Old 04-28-2004, 03:45 PM
STF Veteran
99-LS1-SS's Avatar
I am using the same thing. I got mine from TSP.
