Went from 93' wiring, to 95', now I can't get any fuel!
Old 06-05-2013, 11:34 AM
Tolley's94z28's Avatar
Default Went from 93' wiring, to 95', now I can't get any fuel!
I think it might be one of these bastards, but I don't see where to hook them up at. Any advice om where they go, or how to bypass them would be awesome! thanks in advance!
Old 06-05-2013, 11:43 AM
LS1Tech Sponsor
BP Automotive's Avatar
The small one way connector that looks like its in your hand is just for testing or priming the pump.
What wiring did you change? the dash harness or the interior harness?
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old 06-05-2013, 11:47 AM
I changed the interior, dash, and engine. All that stayed the same was the door harness.
Old 06-05-2013, 11:51 AM
Could it be the prime lead not giving me fuel?
Old 06-05-2013, 02:57 PM
shbox's Avatar
The prime lead is only for testing. You don't normally connect it to anything. What did you use for a guide for matching up leads between the two years? Some adaptation is required. You can find lead differences here.
Old 06-05-2013, 04:00 PM
ah, well I used shbox, but I will confess that I'm not an expert at wiring. Almost everything bolted up perfectly except for a few interior things(changed interior to a 99'). I guess I just assumed it would work fine. So do I need to update my fuel pump too, or just rewire some stuff?
edit: just realized you ARE shbox! I'm not worthy!
Old 06-06-2013, 03:15 PM
I read somewhere that if the computer doesn't read any oil pressure or anything that it won't allow the fuel pump to work. Can anyone confirm this?
upon further inspection, it looks like I broke both of my oil pressure sensors putting the motor in( though I think one was already broken)
Old 06-06-2013, 04:02 PM
shbox's Avatar
Our cars don't use the oil pressure reading for anything other than the gauge.
Old 06-06-2013, 04:25 PM
****. Well anyway, I got a wire and touched the prime lead to the battery and it primed the pump, so I know it isn't the pump itself. I guess I will just have to get a voltage and pressure tester and do some troubleshooting
Old 06-06-2013, 04:42 PM
LS1Tech Sponsor
You changed the dash harness to the 95, engine harness to 95, and the engine to 95. All this is correct?
__________________
1-888-467-4491
Old 06-06-2013, 05:14 PM
dash and engine harnesses are changed to a 95' my engine is a 93'
Old 06-06-2013, 06:06 PM
RamAir95TA's Avatar
What year is your PCM?
Old 06-06-2013, 06:17 PM
It is a 95' as well
Old 06-06-2013, 09:18 PM
shbox's Avatar
Either your relay is not getting power from the fuse or it is not getting the signal to operate from the PCM.
Old 06-09-2013, 09:42 AM
Just checked my relay wires with a voltmeter, and the red wire has 12 volts, but the other three don't. Is the red one the only wire that should show voltage?
Old 06-09-2013, 02:42 PM
shbox's Avatar
What red wire? http://shbox.com/1/1995_pcm3.jpg
-Pink should have +12v with key on.
-Dark green/white should have +12v when the computer commands the pump on (for 2 seconds when the key is first turned on and continuously after the engine is running)
-Black/White = continuous ground
-Gray = +12v to pump when relay is activated
Old 06-09-2013, 02:59 PM
here are my discoveries so far:
pink: 12v
green/white: a very small reading at first then nothing
gray: nothing
at the connector behind the back seat:
the first hole(larger one): nothing
the middle: 7.5v
the last: nothing
the relay never clicks on(I have three of them and none worked)
the vats module I am using is from mu 93' (it is the only one that allows the car to turn over, and the security light goes of after 2 seconds)
. the 95' module will flash security and won't let me do anything.
my circuit tester only lights up on the pink wire at the relay, and at the middle wire at the connector(though it glows faintly for that wire)
first of all, sorry for the long windedness, but I know that more info makes it easier.
second of all, you are a saint, thanks for all the help so far!
Old 06-09-2013, 10:21 PM
shbox's Avatar
You may need to ohm out the green/white wire to make sure it is good from the relay to the PCM. It should be checked to be sure it is not grounded, also.
Old 06-10-2013, 09:47 PM
It isn't grounded. Now, what is the best way to check ohms? Would it just be best to disconnect the wires from the computer and do it that way?
Old 06-12-2013, 12:18 PM
When measuring the green and white wire right after the computer, it will show a very small voltage reading right after turning on the key, but it is negligible (usually less than 1v) and it immediately goes away. I am getting power from the ignition and battery wires to the pcm though, so something is not letting the pcm send power to the relay.
could it be because I am using a 95' ecu and wiring harnesses with a 93' vats module?
Quick Reply: Went from 93' wiring, to 95', now I can't get any fuel!
