1998 car with 1999 wiring harness none of my gauges work
Old 06-06-2013, 11:24 AM
1998 candy camaro's Avatar
Default 1998 car with 1999 wiring harness none of my gauges work
needs help asap
Old 06-06-2013, 11:48 AM
jlcustomz's Avatar
Haven't personally touched a 98 0r 99 gauge cluster to know their specifics. But first off ,if the wiring plugged in just right I'd start diagnosing absolute basics like is it getting proper 12 volt power(fuse??) & has proper ground.
I,d seriously doubt that between a 98 & 99 year there would be enough differences if any to make EVERYTHING not work. Tach could read differently if not both a v-8 unit, but fuel , volts, speedo, etc shouldn't differ.
You gave no detail, so this is the best starting point I can give you.
Old 06-06-2013, 11:51 AM
LS1Tech Sponsor
BP Automotive's Avatar
Need more specifics. Did you swap the dash harness too? If you are swapping harnesses with that setup you have to swap all the interior wiring and the cluster to 99+.
The easiest way to accomplish what you are doing is to repin the 98 harness or have someone repin it for you.
We offer the repin service, will look better than stock when finished.
Please give more specifics on all the parts you used and what you swapped.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old 06-06-2013, 01:24 PM
Old Geezer's Avatar
Quick Reply: 1998 car with 1999 wiring harness none of my gauges work
